I am designing a circuit, to use an ADC(mcp3008) to read voltage, current, and temperature sensors. I have a few questons about this, as I have never done this before.
  1. I am going to use single ended mode; Can I just plug in the sensor directly to the ADC, or does it need to go through some processing or filtering?
  2. I need to read voltages that vary from 90-108v the maximum voltage that my board can supply the ADC for Vref is 12 Volts. How can I read this high voltage?
  3. Are there any additional considerations that I should keep in mind to make my circuit as reliable as possible?
Thank you for your help!
  1. Depends on the sensor output impedance, frequency content, and signal range. If the output impedance is high, you need a buffer. If the frequency content is too high for the ADC, you need a low pass filter. If the signal range is too small, you need amplification.
  2. Use a voltage divider to bring it down to the range in question, then buffer with an op-amp if necessary.
  3. Read about the ADC's input capacitance characteristics. I've written a blog entry that will help explain this. If you're repeating your samples slowly, it's not a big deal, but rapid sampling makes this important. The sampling time before ADC conversion is also important.
    \$\begingroup\$ Thank you for your answer, this really clears things up! \$\endgroup\$
    – Reid
    Mar 24, 2012 at 5:36
  • \$\begingroup\$ Necro comment here, but I found the article super straight-forward and useful. \$\endgroup\$ Sep 12, 2012 at 23:39
