6
I am trying to simulate a LDO with Microchip MCP6001 operational amplifier in LtSpice. With other OA simulation is ok, but with all Microchip models, the same error:
Time step too small; Initial timepoint: trouble with u2:nmi-instance m:u2:12
Here is the model with trouble
.SUBCKT MCP6001 1 2 3 4 5
*               | | | | Output
*               | | | Negative Supply
*               | | Positive Supply
*               | Inverting Input
*               Non-inverting Input
* Software License Agreement                                                   *
* The software supplied herewith by Microchip Technology Incorporated (the     *
* "Company") is intended and supplied to you, the Company's customer, for use  *
* soley and exclusively on Microchip products.                                 *
* The software is owned by the Company and/or its supplier, and is protected   *
* under applicable copyright laws. All rights are reserved. Any use in         *
* violation of the foregoing restrictions may subject the user to criminal     *
* sanctions under applicable laws, as well as to civil liability for the       *
* breach of the terms and conditions of this license.                          *
* THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES, WHETHER    *
* EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED TO, IMPLIED        *
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE APPLY TO  *
* THIS SOFTWARE. THE COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR    *
* SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.     *
* Macromodel for the MCP6001/2/4 op amp family:
*   MCP6001, MCP6001R, MCP6001U, MCP6002, MCP6004
* Revision History:
*   REV A: 21-Jun-02, Created model
*   REV B: 16-Jul-02, Improved output stage
*   REV C: 03-Jan-03, Added MCP6001
*   REV D: 19-Aug-06, Added over temperature, improved output stage,
*                     fixed overdrive recovery time
*   REV E: 27-Jul-07, Updated output impedance for better model stability w/cap load
*   REV F: 09-Jul-12, Added MCP6001R, MCP6001U
* Recommendations:
*   Use PSPICE (other simulators may require translation)
*   For a quick, effective design, use a combination of: data sheet
*     specs, bench testing, and simulations with this macromodel
*   For high impedance circuits, set GMIN=100F in .OPTIONS
* Supported:
*   Typical performance for temperature range (-40 to 125) degrees Celsius
*   DC, AC, Transient, and Noise analyses.
*   Most specs, including: offsets, DC PSRR, DC CMRR, input impedance,
*     open loop gain, voltage ranges, supply current, ... , etc.
*   Temperature effects for Ibias, Iquiescent, Iout short circuit
*   current, Vsat on both rails, Slew Rate vs. Temp and P.S.
* Not Supported:
*   Some Variation in specs vs. Power Supply Voltage
*   Monte Carlo (Vos, Ib), Process variation
*   Distortion (detailed non-linear behavior)
*   Behavior outside normal operating region
* Input Stage
V10  3 10 -500M
R10 10 11 6.90K
R11 10 12 6.90K
C11 11 12 0.2p
C12 1  0 6.00P
E12 71 14 POLY(4) 20 0 21 0 26 0 27 0   1.00M 20.1 20.1 1 1
G12 1 0 62 0 1m
M12 11 14 15 15 NMI L=2.00U W=42.0U
M14 12  2 15 15 NMI L=2.00U W=42.0U
G14 2 0 62 0 1m
C14  2  0 6.00P
I15 15  4 50.0U
V16 16  4 -300M
GD16 16 1 TABLE {V(16,1)} ((-100,-1p)(0,0)(1m,1n)(2m,1m)(3m,1))
V13  3 13 -300M
GD13 2 13 TABLE {V(2,13)} ((-100,-1p)(0,0)(1m,1n)(2m,1m)(3m,1))
R70 1 0 20.6T
R71 2 0 20.6T
R72 1 2 20T
I80 1 2 0.5p
* Noise, PSRR, and CMRR
I20 21 20 423U
D20 20  0 DN1
D21  0 21 DN1
G26  0 26 POLY(1) 3 4   110U -49U
R26 26  0 1
G27  0 27 POLY(2) 1 0 2 0   -440U 39.7U 39.7U
R27 27  0 1
* Open Loop Gain, Slew Rate
G30  0 30 POLY(1) 12 11   0 1
R30 30  0 1K
G31  0 31 POLY(1) 3 4 86 5.25
R31 31  0 1 TC=2.8m
GD31 30 31 TABLE {V(30,31)} ((-11,-1)(-10,-10n)(0,0)(1m,1000))
G32 32  0 POLY(1) 3 4 113.7 3.5
R32 32  0 1 TC=2.65m
GD32 30 32 TABLE {V(30,32)} ((-1m,-1000)(0,0)(10,10n)(11,1))
G33 0 33 30 0 1m
R33 33 0 1k
G34  0 34 33 0 425M
R34  34 0 1K
C34  34 0 74U
G37  0 37 34 0 1m
R37  37 0 1K
C37  37 0 41.6P
G38  0 38 37 0 1m
R38  39 0 1K
L38  38 39 100U
E38  35 0 38 0 1
G35 33 0 TABLE {V(35,3)} ((-1,-1n)(0,0)(16,1n))(16.1,1))
G36 33 0 TABLE {V(35,4)} ((-16.1,-1)((-16,-1n)(0,0)(1,1n))
* Output Stage
R80 50 0 100MEG
G50 0 50 57 96 2
R58 57  96 0.50
R57 57  0 750
C58  5  0 2.00P
G57  0 57 POLY(3) 3 0 4 0 35 0   0 0.67M 0.67M 1.5M
GD55 55 57 TABLE {V(55,57)} ((-2m,-1)(-1m,-1m)(0,0)(10,1n))
GD56 57 56 TABLE {V(57,56)} ((-2m,-1)(-1m,-1m)(0,0)(10,1n))
E55 55  0 POLY(2) 3 0 51 0 -0.7m 1 -40.0M
E56 56  0 POLY(2) 4 0 52 0 1.2m 1 -37.0M
R51 51 0 1k
R52 52 0 1k
GD51 50 51 TABLE {V(50,51)} ((-10,-1n)(0,0)(1m,1m)(2m,1))
GD52 50 52 TABLE {V(50,52)} ((-2m,-1)(-1m,-1m)(0,0)(10,1n))
G53  3  0 POLY(1) 51 0  -49U 1M
G54  0  4 POLY(1) 52 0  -49U -1M
* Current Limit
G99 96 5 99 0 1
R98 0 98 1 TC=-2.8M,2.63U
G97 0 98 TABLE { V(96,5) } ((-11.0,-10.0M)(-1.00M,-9.9M)(0,0)(1.00M,9.9M)(11.0,10.0M))
E97 99 0 VALUE { V(98)*((V(3)-V(4))*359M + 310M)}
D98 4 5 DESD
D99 5 3 DESD
* Temperature / Voltage Sensitive IQuiscent
R61 0 61 100 TC 3.11M 4.51U
G61 3 4 61 0 1
G60 0 61 TABLE {V(3, 4)}
+ ((0,0)(900M,0.0106U)(1.00,0.20U)(1.3,0.63U)
+ (1.5,0.66U)(1.6,1.06U)(5.5,1.10U))
* Temp Sensitive offset voltage
I73 0 70 DC 1uA
R74 0 70 1 TC=2
E75 1 71 70 0 1
* Temp Sensistive IBias
I62 0 62 DC 1uA
R62 0 62 REXP 58.2u
* Voltage on R62 used for G12, G14 in input stage
* Models
.MODEL NMI NMOS
.MODEL DESD  D   N=1 IS=1.00E-15
.MODEL DL  D   N=1 IS=1F
.MODEL DN1 D   IS=1P KF=146E-18 AF=1
.MODEL REXP RES TCE=10.1
.ENDS MCP6001
And here my schematic enter image description here
I guess there is something wrong with the model, but I am not expert in spice to solve it. Thank you in advance,
  • \$\begingroup\$ It seems to me you swapped in+ and in- \$\endgroup\$ Feb 13, 2017 at 12:47
  • \$\begingroup\$ nope, I tried both ways (swap In+ and In-) and the same result error. However, I used notation from original Microchip file. \$\endgroup\$
    – orfruit
    Feb 13, 2017 at 13:04
  • \$\begingroup\$ Sorry, my bad, that's a PMOS, polarity is correct. \$\endgroup\$ Feb 13, 2017 at 13:08
  • \$\begingroup\$ only the Microchip files are not working, I tried the same import with TI's OA, ST and others. Suspect that in spice file is the problem but I don't know what is wrong. \$\endgroup\$
    – orfruit
    Feb 13, 2017 at 13:32
  • \$\begingroup\$ Well, can you tell my why your PMOS is wrongly connected? \$\endgroup\$
    – G36
    Feb 13, 2017 at 16:03
Your not guaranteed that a model from any manufacturer is going to work (and most of models only simulate some of the aspects of a device. (for example: an op amp model may only simulate noise, common mode and input bias current and output current)
I would try validating only the model and run some tests (like .ac tests for bandwidth, a sin sweep in inverting gain, non inverting gain and unity gain) just to see how the model behaves. Then if you throw the model into a different circuit you know it will work.
Secondly there are different solvers that can be changed in the control panel Try a different solver and see if it gives you better results, some solvers work better than others for a given circuit.
Don't change the tolerances unless read up on it first.
  • \$\begingroup\$ I tried, no luck :( Also tried Trtol = 7, but thanks for guide! \$\endgroup\$
    – orfruit
    Feb 14, 2017 at 8:14
  • \$\begingroup\$ I cannot vote but I gave ok, thank you! \$\endgroup\$
    – orfruit
    Feb 15, 2017 at 8:01
Hmm.. I found it :) In case anyone struggle like me. Not sure how would impact my simulation, but adding extra option to LtSpice at least started simulation:
.options cshunt = 1e-13
However, simulation is horrible slow :(
    \$\begingroup\$ That adds capacitors to EVERY node, and basically smooths out numerical noise. In some simulations I have added small pF capacitors to certain (like the output of an opamp) or nodes that have numerical noise. \$\endgroup\$
    – Voltage Spike
    Feb 14, 2017 at 16:40
  • \$\begingroup\$ Ok that saved me. Did you find the solution somewhere in the web? I want to know more about why it needs that option to run properly \$\endgroup\$ Mar 31, 2021 at 20:24
Old thread but the question remains. I had the same issue and finally I solved my own issue. I post my findins here in case it helps anyone else googling the issue.
NOTE: This applies only to issues related to "Initial timepoint" Short answer, try:
  1. Check "Start external DC supply voltages at 0V"
  2. Un-check "Skip initial operating point solution"
Why does this help? My guess is that the problem is two-fold.
a. If you cannot find a stable operating point (self-oscillating circuits may not have a stable operating point) you must "Skip initial op point".
b. Without a stable op-point all capacitors and coils are initiated at 0V and 0A. Then applying supply-voltages as a step at the initial timepoint may cause numerical problems
But when using "Start external DC supply voltages at 0V" the self-oscillating cirtuits will not oscillate and an operating point can be found. And because the voltage sources are applied as a ramp (default during 20us) there will be no infinite derivates and the simulation seems to work much more stable.
