I've got a small 12VDC pump that I used on an old project. I now want to use the pump on a different project and make use of a 24VDC transformer I have (because the project also makes use of a 24VDC solenoid valve).
The description on the side of the pump says:
Power 15W 6-24V DC (rated at 12V DC)
I originally bought this as a 12VDC pump so my rather obvious question is can I run this on 24VDC safely without damaging it? Secondarily, will it make the pump run faster or more powerfully?
