Why do some TSOP1738 have a metal cross over their optical window while some do not have this cover?
Does not it obscure the view and shorten the range of the sensor? Does it have some positive effects?
Compare these two:
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhy do some TSOP1738 have a metal cross over their optical window while some do not have this cover?
Compare these two:
It is a shielding against EMI or RFI interference,
According to this article
TSOP module has an inbuilt control circuit for amplifying the coded pulses from the IR transmitter. A signal is generated when PIN photodiode receives the signals. This input signal is received by an automatic gain control (AGC). For a range of inputs, the output is fed back to AGC in order to adjust the gain to a suitable level. The signal from AGC is passed to a band pass filter to filter undesired frequencies. After this, the signal goes to a demodulator and this demodulated output drives an npn transistor. The collector output of the transistor is obtained at pin 3 of TSOP module.
Members of TSOP17xx series are sensitive to different centre frequencies of the IR spectrum.
so to avoid EMI/RFI, some of this module have the shielding, build over it
