I have a One Shot Type Thermostat CS-7TA-35 195 6103 that i've removed from a laser printer's fuser unit.
There was a paper jam within the fuser unit which I assume tripped this "one shot" by metalic strip.
1) when the device reaches its operating temperature, does it act like a conventional fuse and go open circuit? It's open circuit now.
2) Is there a way to reset the device, or do I need a new one?
3) Am I correct that this device will operate at 180 degrees celsius?
  • \$\begingroup\$ I would normally refer to that kind of device as a "thermal fuse" because it is not resettable. Once its 'trip' condition has occurred it needs to be replaced. \$\endgroup\$
    – brhans
    Feb 15, 2017 at 14:15
  • \$\begingroup\$ "One Shot" gives you the answer. \$\endgroup\$ Feb 15, 2017 at 14:27
I've managed to reset the device.
There is an oblong piece of mettle set in a round space. This allows one to get a small piece of wire (none flexible, i.e. a pin) under the metallic strip and snap it up; it then becomes loose ish.
Ive tested it with a lighter and it clicks then becomes open circuit.
I guess it's a one shot in reality, because it's not designed to be reset.
This quick fix will get you going until you can get a replacement part.
