-5
I want to take a +12V power supply and duplicate it creating
1- +12v out 1- -12v out
easier said than done?
  • \$\begingroup\$ what else power supply is available? how much current /load are you expecting for the generated dual polarity 12 V? \$\endgroup\$ – Umar Feb 16 '17 at 7:27
  • \$\begingroup\$ What you are looking for are dc/dc converters. \$\endgroup\$ – Botnic Feb 16 '17 at 7:30
  • \$\begingroup\$ What power? For low power you can use switched capacitor voltage converter LM7660. \$\endgroup\$ – Curd Feb 16 '17 at 10:38
  • \$\begingroup\$ Less than 1A. Yeah DC/DC converter schematic is what I need! \$\endgroup\$ – Thebosshagz Feb 16 '17 at 15:06
  • \$\begingroup\$ Look at 75XX equivalent DC to DC converters from CUI (and a few other companies, some can't go negative), they can be put in positive and negative modes and their easy to use. \$\endgroup\$ – Voltage Spike Feb 16 '17 at 16:56
What you need is a switching inverting regulator capable of dealing with +12V at its input and supplying enough current for your application.
However, keep in mind you'll require additional components and that laying out a good PCB may be critical! It will be something like this (the image shows +5V to -5V but the device is capable of +12V to -12V as well):
Inverting converter
Some devices that you may find useful:
You may also like to consider a commercially available pre-assembled board.
You can use something like TPS65131-Q1, a positive and negative output DC-DC converter. Below is an application schematic diagram:
TPS65131-Q1
Note that this converter can take only 2.7--5.5V on its input while having dual output up to 15V and down to -15V. For this reason you would have to:
1) Choose a more suitable DC-DC converter that has a dual positive/negative output.
2) Step down potential difference from the output of your power supply (+12V). You can use a linear voltage regulator or a simple buck converter. It depends on how much current the load needs. Also, it would be good if this buck converter wouldn't switch at the same frequency as TPS65131-Q1 (minimum 1.25Mhz).
