8
I have an 8-line bus chselect[7..0]. I also have a 4x repeated subsheet, each of which has two inputs CSAb and CSBb. Denote these inputs as CSAb_0, CSBb_0, CSAb_1, CSBb_1,...,CSBb_3 where the number after the underscore indicates which instance the instance of the repeated subsheet.
I want to connect the bus like this:
chselect[0] --> CSAb_0
chselect[1] --> CSBb_0
chselect[2] --> CSAb_1
chselect[3] --> CSBb_1
chselect[4] --> CSAb_2
chselect[5] --> CSBb_2
chselect[6] --> CSAb_3
chselect[7] --> CSBb_3
Here's my attempt in Altium
Is this correct and/or in line with best practice?
I have also asked this on the Altium forum.
  • \$\begingroup\$ Without having time to go into Altium right now I suspect it'll be a lot easier on you if you can regroup it so all CSA can be [0..3] on chselect and CSB on [4..7]. If possible. \$\endgroup\$
    – Asmyldof
    Feb 23 '17 at 6:20
An approach that works:
Inside digital_interface.SchDoc, group the pins as shown in Figure 1.
enter image description here Figure 1: Digital pins grouped into two busses. Each bus will be connected to one input of the channelized block.
Then, in the top level sheet, just use standard channelization as shown in Figure 2.
enter image description here Figure 2: The CSAb and CSBb busses are channelized in the usual way.
This isn't as elegant as I'd like, but it works.
