I have 8 x TEC modules each with specs 12V, 6A, and I have a power supply of 12V, 10A.
If I connect all them in series, I know current stays the same and voltage increases.
- But what I'm unable to understand is that will be voltage divided equally among the modules?
- Also, will the cooling effect decrease with low voltage input? What's the relation of cooling effect with voltage and current?
- To run all the modules with full effect, what kind of power supply will I need?
- Currently, when I run two modules with my power supply, I don't get temp. lower than 10°C. What could be the problem?
