I am working on some PCB with an ATmega328P on it. I use a Pogo connector because we have to program and test the PCB outside.
I program with usbTiny
, (mosi/miso/rest/clk/power
Anyway, many times during programming I move a little bit which disturbs the Pogo pin contacts and get a verification error. Then I start again and flash it successfully.
But sometimes, after a movement and a mismatch on verification, I can not flash it any more, like now.
I get :
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
An error occurred while uploading the sketch
I got extremely tired from manufacturing again and again :( and I am sure the chip is still OK. This will probably happen again.
I have read that there are ways to save it, like serial programming or oscillator.
How exactly can I do this with serial?
VERBOS:
Using Port : usb
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 020:013
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
