I have an Ethernet peripheral (manual here) controlled by an STM32. I have to test that the Ethernet peripheral works correctly right after the board is manufactured. Conveniently, there are three "loopback" modes for testing. (See page 41: near-end, far and connector loopback.)
I wonder if using these three loopback testing modes (doing basic I/O) is sufficient to guaranty that the Ethernet peripheral will work properly in production.
Are there non-loopback tests that I should consider to test the integrity and functionality of my Ethernet peripheral?
I basically just plug it in and have it do a request, make sure the data gets through OK.
Test heavy data transfers (or at least as heavy as the design will be rated to handle), try as many different hubs/switches as you can (10, 10/100, Gbit, etc). Try different duplexes, etc.
In my experience, if the design is sound and one unit verifies OK, the hardware is not the likely point of failure - issues are more likely to crop up in the TCP/IP stack or application code.
