-1
I am currently soldering a new Analog Axis for a friend and the tin to help ground the solder to the joint has burned off and now the tin either goes to the tip or the solder itself. I have no idea how to get the tin to "stick" to the board now. Any help would be very appreciated! Thanks
closed as unclear what you're asking by Olin Lathrop, Leon Heller, Wesley Lee, Voltage Spike, DoxyLover Feb 24 '17 at 1:55
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Do you have any flux handy? \$\endgroup\$ – Andrew Feb 22 '17 at 13:59
  • \$\begingroup\$ Sounds like you have dirty, oily connections. Clean them up and maybe use flux. \$\endgroup\$ – Rob Feb 22 '17 at 14:00
  • \$\begingroup\$ As well as flux, use a scalpel tip to shine up the metal before trying to re-tin it. \$\endgroup\$ – Brian Drummond Feb 22 '17 at 14:00
  • \$\begingroup\$ Are you sure you haven't damaged the pad to the point where it came off and you are trying to solder to the bare board? Maybe a photo would help. \$\endgroup\$ – AngeloQ Feb 22 '17 at 14:52
  • \$\begingroup\$ Use a brass sponge to clean the tip \$\endgroup\$ – Voltage Spike Feb 22 '17 at 18:18
As others have said, make sure your soldering iron tip is clean. Use a damp sponge or paper towel and wipe off any old, burned flux. Once you've done that, make sure you're using solder meant for electronic soldering. I use 60/40 solder with rosin core flux. Adding rosin flux to the connections you are trying to solder will help the solder flow onto these parts more easily. Do not use acid core flux- that's for plumbing.
Put a coating of solder on the parts you want to join. Make a mechanical connection if you can (twist wires, etc...). Heat the joint, not the solder. This helps eliminate cold solder joints. Don't move anything until the solder solidifies.
All of these suggestions are best practices, but sometimes 'good enough' is, well, good enough. There's a number of howto guides on the net- here's one.
