How does slave identification takes place in LIN protocol by the master ?
What is the default status of a LIN bus ?
How are collisions avoided in LIN ?
What is the role of Sporadic frame ?
  • \$\begingroup\$ The question you really need to ask is "How do I use Google?" Then you could have found this page by yourself. \$\endgroup\$ – Finbarr Feb 23 '17 at 1:03
  • \$\begingroup\$ Not even one of the above are found in Google mr.Finbarrrrrrr \$\endgroup\$ – Anjaneyulu Feb 23 '17 at 1:11
  • \$\begingroup\$ You've proved my point. Try just typing "LIN bus" into Google. Without the double quotes. \$\endgroup\$ – Finbarr Feb 23 '17 at 1:18
  • \$\begingroup\$ my question is nor introduction to LIN bus \$\endgroup\$ – Anjaneyulu Feb 23 '17 at 1:45
  • \$\begingroup\$ I know, sometimes you have to actually read an article to find the answers you're looking for. What a chore, eh? I can see the answer to one of your questions in that article straight away and I haven't even read it. \$\endgroup\$ – Finbarr Feb 23 '17 at 10:47
your questions are good enough and are logic because they are not clearly answered in the iso. The default status of the lin bus is sleep. However the master can either do sporadic or do continous quering. Sporadic means it wakes up the bus and queries for a short time some device and sleeps again. Collision is avoided by the master schedule tables. Specs from the Lin Consortium
| improve this answer | |
