Hi all, I am very new to electronics. In the diagram shown here, where should I connect the pin of R4 variable resistor.
    \$\begingroup\$ Have you read this: en.wikipedia.org/wiki/Potentiometer ? If not, do so now. With just a tiny bit of effort you can understand how such a resistor is build and from that figure out how to connect it. Also just measuring one with a multimeter can be very educational. \$\endgroup\$ Feb 23, 2017 at 10:24
    \$\begingroup\$ "the pin" if your R4 only has one pin you are doing something wrong. \$\endgroup\$
    – PlasmaHH
    Feb 23, 2017 at 10:27
  • \$\begingroup\$ Show us the picture of your variable resistor. How many pins your variable resistor has? \$\endgroup\$ Oct 26, 2018 at 10:20
Actually you can see this component like two singles resistors mounted in dividing bridge.
Admitting you want to divide a 10V supply, the resulting voltage of the divider is in the middle of the potentiometer and the ground (in this case).
Just connect the wiper terminal to any of the other 2 terminals and you'll be fine. This way, a part of the total resistance gets shorted and current only flow through the rest of it (thus becoming your variable resistor).
However, be careful: when applying a voltage to a potentiometer connected like this, you may easily exceed its current rating if you reduce to much its resistance value. You may want to add a fixed current limiting resistor in series to avoid this.
