This is the datasheet of a mosfet and I have two issues:
http://www.ram-e-shop.com/ds/tr/IRFP150.pdf
First, I can not find the pinout diagram. I don't know where drain, source and gate are. Which pin is gate and which is drain?
Second, Drain-to-Source Breakdown Voltage (VDSS) = 100 V.
When I hear the word "Breakdown", I feel like it is OFF characteristic. I think if I applied more than 100V while the transistor is OFF, A damage will occur. What I mean by "OFF" is when the gate voltage is zero (no gate signal) or when the MOSFET is reverse-biased (i.e. Drain voltage is 0V and source voltage is +100V).
But I don't know the normal drain-source voltage when the MOSFET is on. What is the maximum supply voltage or the maximum operating voltage? Is It 100V too?
Thank you very much,
