For some time I have used the K150 PIC programmer but I was tired of some strange behaviour so I purchased an Original PICKIT3 programmer/debugger. During programming a 16F648A I receive the following message. "You're attempting to program a release platform with a debug build. Do you want to rebuild? This message keeps appearing time after time. I do not understand the reason nor can I find a solution to this problem.
After indicating that I do not want to rebuild the programming continues without problems. Reprogramming results in the same message.
When moving over to the debugger the program reports: Target Device (00001100) does not match expected Device ID (00001120). For this I also can not find an explanation. The same message happens with different projects that are all running without a problem.
So two questions. 1. Why do I keep a sustained warning message during programming? 2. Why can there be a device mismatch?
I looked all over but can not find the reason.
Extra information: The program is generated in debug mode since that is what i require for the on line debug procedure.
