I have been trying to create a countdown timer using ARM7 micro-controller, once an switch input has been detected. So far I managed to create a delay function of 1 minute, and detect a switch input. However, once the switch is released, the countdown will stop.
First I have set up 2 Seven Segment displays which detect a switch input and can increment or decrement the minutes.
I have set the delay_MINUTE function as follows which is basically a 1 minute delay. I have checked this using an LED and this part of my program is working:
  void delay_MINUTE(void)
 T0TCR = 0x0;                   //Resetting Timer0
 T0MR0 = 499999;                //Loading match register value
 T0PR = 600;                  //Loading Prescalar register value
 T0PC = T0TC = 0;             //The value in the register increments with   every     input pulse or Processor clock fed into it.
 T0MCR = (1<<0) | (1<<2);     //Generates interrupt and reset on match.
 T0TCR = 0x1;                   //Starting Timer
 while(!(T0IR & (1<<0)));       //Waiting for interrupt
 T0IR = (1<<0);               //Clearing interrupt
I am getting stuck in a simple part of the program. When a switch input is detected on P0.14, the current display should decrement by one, every one minute.
If I simply do:
     int y = 0;
     unsigned int SW3;
     if((SW3) == y)  //detecting switch input
        delay_MINUTE();
        num_right --;
the number will only decrease by one when the switch is pressed, and not keep on counting down until it reaches 0. Any suggestions on how I could change my code to detect one switch input and continuously decrement after it has been released would be appreciated.
EDIT I have also tried creating a for-loop inside the switch statement such that when the switch is pressed, the countdown will start depending on the current digit being displayed. I am not sure if this is a good idea or not.
try this:
if (sw3_pressed())
  while (num_right--) delay_Minute();
  • \$\begingroup\$ Are you assuming a function here? I was detecting switch input just by using if((SW3) == y) or something of the sort \$\endgroup\$
    – Rizzo
    Feb 25, 2017 at 15:56
