7
I have 9 18650 cells salvaged from a laptop battery. They have all been tested to work and since they were always used together, I put them in parallel. I'd like to make a power pack, so I got some lithium charging circuits with all the protection bells and whistles, but with just 1A max output current. Now, I've been charging them with the circuit board from another old USB power pack, and it works, it's just super slow. Someone mentioned that the 1A max current simply would not work for 9 parallel cells, but I don't fully understand how it couldn't. As long as I'm charging the batteries with more current than I'm drawing from them, they should charge, right? I'm not super worried about the speed, right now it takes pretty much a full day to charge the pack. My question is, will the pack charge with a 1A total charging current (albeit slowly), or am I missing something?
6
Nonsense !!! it will work but it will take a very long time to charge. One cell of 2000 mAh (=2 Ah) (a typical 18650 is 2 - 2.5 Ah) takes 2 hours to charge so 9 cells take 9 x 2 = 18 hours to charge. Close to a full day indeed, not all the energy ends up in the cells and is lost so in practice 1 day sounds right.
Yes, that is correct.
Next time someone gives an opinion about things always ask why and ignore their advice if they cannot give a good explanation.
    \$\begingroup\$ I'm not sure of the capacity of the cells, they're unmarked, and they have red jacketing on them. With 9 of them in parallel, a 100mA load runs for about 6.5 days, using the USB power pack circuit board, which does include over-discharge protection. I just haven't done the math yet. \$\endgroup\$ Feb 28, 2017 at 13:39
    \$\begingroup\$ That cell capacity is mentioned is for new cells. Since you salvaged your cells they will have some wear and could easily be at half their nominal capacity. But as long as the charging stops when the cells are full, there is no danger of overheating or overcharging. \$\endgroup\$ Feb 28, 2017 at 13:48
    \$\begingroup\$ @HaLo2FrEeEk 100mA for 6.5d. Considering that the USB converter has an efficiency of about 90% (but for that current you can easily assume 80%), the batteries store energy to give you 100mA for about 8d. This means that at 1A you will get 0.8d. Consider then that not all the energy you put in the battery is stored, that higher currents are less efficient for the battery and so on and this means that charging at 1A can roughly take one day... \$\endgroup\$
    – frarugi87
    Feb 28, 2017 at 14:45
7
There could be some legitimate reasons why this won't work well. These may not apply to you, and if you review the documentation of your charger, you should be able to tell whether these things apply.
Probably you are aware that it is not safe to float lithium ion batteries at 4.2V indefinitely. Because of this, all Lithium ion chargers use some method of recognizing end of charge.
Typically, end of charge is determined by how much current flows into the battery. For a single 18650 cell, end of charge may be defined as the point where charge current drops to 25mA during the CV stage. But with 9 cells in parallel, it may never drop that low.
Which brings me to the second point. Timeout. Many charger IC's will not allow an indefinite amount of time for charge to complete. This is a backup safety in case a defective battery is present, or something else prevents the primary charge termination condition from occurring. Typically this timeout would be set to some number far larger than you would expect to ever happen unless something is wrong with the cells. On a C/3 charger, you would set it to 5 hours or 8 hours. If your charger has a feature like this, it could possibly prevent the pack from charging fully. You would have to remove the pack, and put it back in to restart the charge timer.
Again, without seeing your charger details, I can't say whether these two issues apply to you. But you may want to check it out or at least be aware and keep your eyes open.
    \$\begingroup\$ Apologies, for some reason it didn't even occur to me to post the charger I bought. It's this one, from Banggood: banggood.com/… it says. Not a ton of information included on the product page... \$\endgroup\$ Feb 28, 2017 at 13:34
For your information, your charger is based on TP4056 chip, programmed to 1A charge current. There's no safety timer, meaning it will continue to charge until the charge current drops to 100mA:
Other than being slow, there are no apparent problems with your charger.
  • \$\begingroup\$ Excellent. Thank you for the answer. I can't wait to get them in the mail and start working on the new power pack. \$\endgroup\$ Feb 28, 2017 at 23:19
