I am trying to apply soldering paste to a PCB using stencil but I am having issues with S-PQFP-G80 package with 0.5mm pitch.
Whenever I try to apply the paste through the stencil I end up with paste being smeared all over the pads on the PCB. I am using eC-stencil-mate holder and I just can't make the damn stencil stay in contact with the PCB. Do you have any advice or experience with this?
Apart from that I also have a pick and place machine with solder paste dispenser but I can't seem to find the right combination of paste, needle gauge, dispensing time for this package. Since the pad width is 0.3mm I was using 27 gauge needle but the paste just doesn't go out of the dispenser. Again, any ideas or advices?
  • \$\begingroup\$ that's for mass production, right? \$\endgroup\$
    – Nazar
    Feb 28, 2017 at 13:12
  • \$\begingroup\$ Yes. Around 100 pieces. \$\endgroup\$
    – MarkoP
    Feb 28, 2017 at 13:15
  • \$\begingroup\$ Stainless or plastic stencil? \$\endgroup\$
    – uint128_t
    Feb 28, 2017 at 16:09
  • \$\begingroup\$ Stainless stencil. \$\endgroup\$
    – MarkoP
    Mar 1, 2017 at 13:59
  • \$\begingroup\$ Did you solve your problems? I am also looking at the eC-stencil-mate as it looks like a nice printer with great registration. I was a bit worried when I read your post. Can you give an update and some thoughts on the printer please? Thanks. \$\endgroup\$
    – Reneli
    Oct 31, 2017 at 23:49
You will have a hard time using a needle to dispense accurately for 0.5mm pitch pads. But you might have better success with a different paste. I used to use this Kester solder paste but I found this ChipQuik flows better (NOTE: these both have lead). Or maybe your paste is older; it will get hard to dispense as it ages, I found.
If I'm manually applying paste for parts like that I usually just apply a straight bead along all the pads and clean it up afterward if necessary. It is possible to get the bead size (pressure and speed) just right that there are no solder shorts after reflow, but it takes some trial and error.
As for the stencil, I don't know how you have it set up, but the stencil should just lay flat on the PCB. Sometimes I need to add dummy PCB material around the PCB I'm pasting (if it's not a full panel) to keep the stencil level. Of course your stencil should not be warped or dented when you start. I'm assuming a stainless stencil. I tried the cheap plastic ones, but they come in a roll and don't always come out completely flat. I stick with SS now and they are shipped flat between two thick boards so they are good.
Even if there is some gap, once you start applying the paste with the squeegee, it should flatten the stencil out before the paste gets to the openings. I find the issue is more with removing the stencil afterward. I don't use a stencil holder, I just align the stencil and tape it to the panel. If you are not using panels, I suggest taping the PCB to a board along with other spacer PCBs to provide even elevation, and then tape the stencil to the spacers. The tape is not ideal as it adds a small gap, so put it in an area as far as possible from SM components. At least that's what I do, but I haven't tried using something like the stencil holder you use.
I find it's difficult to apply all the paste in one pass of the squeegee so it's very important that the stencil doesn't move so you can pass over it again. If the stencil is not laying fairly flat to start with, and it lifts off after one pass, this could be causing your smearing problem. Do whatever you have to do to get the stencil laying as flat as possible on the PCB before applying the paste and it should be OK.
All that being said, I still have some issues using stencils on 0.5mm pitch parts. Sometimes they come out perfectly but other times not. I find it's more about the paste thickness than smearing though. Even with the same thickness stencil, the evenness of the paste application is influenced by squeegee technique. Like with using a dispenser, I think you will have to go through some trial and error to get your process tuned right. It can be done.
  • \$\begingroup\$ I am using the same paste and the SS stencil. I guess also the problem is coming from the fact that I can't apply all the paste in one go. I will give it a couple more tries but I guess I'll just end up manually soldering the chip. - _ - \$\endgroup\$
    – MarkoP
Here is some things that I do but for much shorter runs (qty 10 max)
1) Use kapton tape to hold the PCB and stencil down, or tape guides down if your doing a larger run so you can easily drop boards in. Its better to align the stencil each time a new board is run
2) Use a squegee to run the paste across the stencil (that's what stencil's are for), not for dispensers.
You can use a dispenser with small pitch components, but instead of trying to cover each pad, you run a strip of paste on the outside. The paste and flux will stick to the pads and some pins will be shorted together, it is easily cleaned up with a soldering iron and flux.
If your doing large runs on a regular basis, make sure your using a metal stencil and a stencil printer.
  • \$\begingroup\$ I am using the squegee with the stencil, not with the dispenser. I am a beginner but not that level of beginner. :D I just had a wildest idea of smearing the paste with my finger through the stencil openings :D \$\endgroup\$
    – MarkoP
    Mar 1, 2017 at 14:01
