Hello Everyone!
I am going through transistors and trying to apply it to some RF applications. I am following Sedra and Smith. In the Sine wave generation section (via feedback), it says if the base input amplitude (a in diagram) increases in magnitude, the effective transconductance decreases. I can not figure out why.
The only way I can think of to decrease the transconductance is to reduce the collector current as, $$g_m=\frac{I_c}{V_T}$$But how come increasing the amplitude of input voltage decreases my collector current? Another way I can think of is in terms of from collector-emitter voltage. Say my input voltage is increasing, hence the emitter voltage must increase, hence the emitter current. But then increasing emitter current means increasing collector current. So instead of decreasing collector current I am getting increasing one. What am I missing here??
Thanks in advance.
  • \$\begingroup\$ The confusing thing is that the reducing gm is the large signal gm. Generally we use gm in the context of small signals. But oscillators also depend on large signal behaviour. If you describe an oscillator's behavior as linear and small signal then there would be no way to control the amplitude, the signal would grow to infinity. In practice this does not happen because for larger signals the gm reduces, which is what they mean. And that reduction in gm/gain limits the oscillator's amplitude. \$\endgroup\$ Mar 1, 2017 at 12:29
I agree that the (short) explanation as given in Sedra/Smith is a bit misleading. In the corresponding chapter (sinewave generation) they speak about amplitude control - which means: Output amplitude limiting for rising input amplitudes (to avoid hard-clipping effects).
For this purpose, each oscillator needs a certain non-linearity (amplitude-dependent gain characteristics). In most cases, this is implemented using extra components (diodes, FET, light bulb, NTC, ..). However, when transistor-based oscillators are concerned, we can make use of the inherent non-linearity of BJTs: The output current cannot grow without limitations because - at the same time - the voltage drop across the collector resistor increases - thereby reducing the remaining collector-emitter voltage VCE (the momentary operational point on the load line approaches the limit VCEsat).
As a consequence, the current IC cannot follow anymore the input signal increase - and hence the instantaneous ratio g=IC/VBE reduces. (Note that both values IC and VBE are NOT DC values but momentary values).
This is not a sudden effect but a rather "smooth" effect - and the overall gain reduction (with rising amplitudes) causes acceptable distortions (in most cases, if the excessive gain for small amplitudes was not too large).
Remark: Please note that the expression g=IC/Vt is a small-signal parameter - it is the slope of the exponential curve IC=f(VBE).
This site is temporarily in read-only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
