I have a project with arduino and the magnetometer CMPS11. I wanted to know how often the CMPS11 should be calibrated using this procedure: https://www.robot-electronics.co.uk/htm/cmps11i2c.htm
  • \$\begingroup\$ Identify the chip used. Get the data sheet and read what it says. \$\endgroup\$ – Andy aka Mar 1 '17 at 14:49
Calibration of the CMPS11 for horizontal only operation. So it should not have an issue if you do not calibrate it often. As tilt does not need calibration.
