this is the error: Error (10500): VHDL syntax error at Bin7SegDecoder.vhd(15) near text "when"; expecting ";"
It may be simple but I don't know what's the error. Thanks in advance!
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity Bin7SegDecoder is
port( enable : in std_logic;
binInput : in std_logic_vector(3 downto 0);
decOut_n : out std_logic_vector(6 downto 0));
end Bin7SegDecoder;
architecture Behavioral of Bin7SegDecoder is
begin
process(binInput, enable)
begin
if (enable = '1') then
decOut_n <= "1111001" when (binInput = "0001") else --1
"0100100" when (binInput = "0010") else --2
"0110000" when (binInput = "0011") else --3
"0011001" when (binInput = "0100") else --4
"0010010" when (binInput = "0101") else --5
"0000010" when (binInput = "0110") else --6
"1111000" when (binInput = "0111") else --7
"0000000" when (binInput = "1000") else --8
"0010000" when (binInput = "1001") else --9
"0001000" when (binInput = "1010") else --A
"0000011" when (binInput = "1011") else --B
"1000110" when (binInput = "1100") else --C
"0100001" when (binInput = "1101") else --D
"0000110" when (binInput = "1110") else --E
"0001110" when (binInput = "1111") else --F
"1000000"; --0
else
decOut_n <= "1111111";
end if;
end process;
end Behavioral;
ghdl -a --std=08 bin7segdecoder.vhd
(in ghdl 0.34-dev) so you may have to check the quality of your simulator's VHDL-2008 support or upgrade to a better simulator. \$\endgroup\$
