Suppose I have a library consisting of TWI.h and TWI.c which contains an ISR defined according to AVR-GCC syntax. For example:
ISR(TWI_vect)
   switch(TWCR)
Should the ISR code go into TWI.h or TWI.c? Or should I put the full ISR in TWI.c and put some sort of ISR "prototype" in TWI.h?
    \$\begingroup\$ Generally, any executable or memory consuming code should go into the *.c files. There are cases it is not like that, but they should be well justified. \$\endgroup\$ – Eugene Sh. Mar 3 '17 at 18:56
The ISR belongs in the .c file. It's a function that directly generates code that's linked into the executable (that is, it isn't an inline-only function), so that's where it goes.
The ISR shouldn't be called by other functions, so it does not need a declaration in the header file.
Too minimize scoping issues, only those referenced by a calling party should be in the header.
Your Isr is generally not called by others so make it private to thee .C files IS thee way to go.
What I generally do is to insert a call back function in there soon that the user can install his own Isr.
