I wanted solder 2 pins to the positive and negative holes of this usb booster circuit, but I am not sure if it will still work. Please, will the connection work if I do this? Thank you for any help! enter image description here
  • \$\begingroup\$ Soldering won't hurt you once its applied on the board if you take care of any possible short-circuits. What you may need to take care of is the heat of your iron. That heat may damage few of the ICs attached on the board already. \$\endgroup\$
    – udiboy1209
    Mar 4, 2017 at 0:12
Yes, it will work. There is nothing special about jumper wire. Solder it using normal soldering techniques.
