My question is for firing angle(alpha)=0,why is T1 triggered at 30?
  • \$\begingroup\$ Because you should draw a rectified voltage from six diode bridge. Then you will notice that diodes doesn't start conduct at \$\omega t=0\$, but they switch when one phase becomes more positive than other. \$\endgroup\$ – Marko Buršič Mar 4 '17 at 13:08
  • \$\begingroup\$ @MarkoBuršič can u please elaborate? \$\endgroup\$ – nrb Mar 4 '17 at 17:32
The sinusoidal wave is positive for 180 degrees.
The switched half-cycle is stepped on at 30 derees, and stepped down at 150 degrees to align withe she sinusoidal wave.
The positive half cycle is from 0 to 180 in the diagram below.
Here is some ascii art depicting the stepped approximation of a sine wave:
    ____________
___|            |______               ___
                       |_____________|
0  30          150    210           330 360
    \$\begingroup\$ But for alpha=0 it should conduct from wt=0 right? \$\endgroup\$ – nrb Mar 4 '17 at 5:15
  • \$\begingroup\$ Yes, it will conduct in the interval \$ [ 0 ; {4 \pi / 6} ] \$ leading 30 degrees. \$\endgroup\$ – skvery Mar 4 '17 at 5:19
  • \$\begingroup\$ Try this first. Draw the stepped three-phase inverter currents. See how they commutate every 60 degrees. Then add the sinusoidal wave one of these approximates. See you in chat. \$\endgroup\$ – skvery Mar 4 '17 at 5:27
