I have tried to simplify a boolean function. Unfortunately it is wrong.
Question: Where is my mistake?
\$ f = x_4x_2 + \overline {(x_3 + x_2)x_2 \cdot 1} + x_2 x_0\$
\$ f= x_4 x_2 + \overline {(x_3 + x_2) x_2} + x_2 x_0\$
\$ f = x_4 x_2 + ( \overline{x_3} \overline{x_2}) + \overline {x_2} + x_2 x_0\$
\$ f = \overline { \overline {x_4 x_2 + (\overline {x_3} \overline{x_2}) + \overline {x_2}+ x_2 x_0}} \$
\$ f = \overline { \overline{x_4} + \overline{x_2} (x_3 + x_2) x_2 \overline{x_2} + x_0}\$
\$ f = \overline{ \overline{x_4}+ \overline{x_0}} \$
\$ f = x_4x_0\$
The correct solution would be:
\$ f = \overline {x_2} + x_0 + x_4\$
  • \$\begingroup\$ in step 3 it should be x3x2 not x3+x2 \$\endgroup\$ – Vladimir Cravero Mar 4 '17 at 10:25
  • \$\begingroup\$ The negation over x3x2 at line 3 is splitted in Android EESE application, but a single line in Samsung's default web browser. The real error is how your double negation is expanded after line 4. That double negation is totally unnecessary action. \$\endgroup\$ – user287001 Mar 4 '17 at 12:36
The error is in line 3. It should be like this:
$$\overline{(x_3+x_2)x_2} = \overline{(x_3+x_2)} + \overline{x_2} = \overline{x_3} \cdot \overline{x_2} + \overline{x_2} = \overline{x_2} (\overline{x_3} + 1) = \overline{x_2}$$
This gives you:
$$x_4x_2 + \overline{x_2} + x_2x_0 = x_2(x_4+x_0)+\overline{x_2}$$
To simplify this, we can write:
$$\overline{\overline{x_2(x_4+x_0)+\overline{x_2}}} = \overline{(\overline{x_2}+\overline{(x_4+x_0)}) \cdot x_2} = \overline{\overline{x_2}\cdot x_2 + \overline{(x_4+x_0)} \cdot x_2} =$$ $$= \overline{0+\overline{(x_4+x_0)} \cdot x_2} = (x_4 + x_0) + \overline{x_2}$$
which is equal to \$x_4 + x_0 + \overline{x_2}\$.
You can always write a simple C program to see where did you go wrong.
Here you go:
#include <stdio.h>
#include <stdint.h>
int main(void) {
    uint8_t byte;
    /* A number of all possible combinations.
    For 5 variables it would be 0b11111 etc. */
    uint8_t MAX = 0b1111;
    /* Print header */
    printf("x4 x3 x2 x0 | f1 f2 f3  f\n");
    for (byte=0; byte<=MAX; byte++)
        /* Get individual bits (combinations) */
        uint8_t x0 = (byte & (1<<0)) >> 0; /* my x0 is your x0 */
        uint8_t x1 = (byte & (1<<1)) >> 1; /* my x1 is your x2 */
        uint8_t x2 = (byte & (1<<2)) >> 2; /* my x2 is your x3 */
        uint8_t x3 = (byte & (1<<3)) >> 3; /* my x3 is your x4 */
        /* Logic functions */
        uint8_t f1 = (x3 && x1) || !((x2 || x1) && x1 && 0b1) || (x1 && x0);
        uint8_t f2 = (x3 && x1) || !((x2 || x1) && x1) || (x1 && x0);
        uint8_t f3 = (x3 && x1) || !(x2 && x1) || (!x1) || (x1 && x0);
        /* Final solution */
        uint8_t f = (!x1) || x0 || x3;
        /* Print truth table */
        printf(" %d  %d  %d  %d |  %d  %d  %d  %d", x3, x2, x1, x0, f1, f2, f3, f);
        /* Print wrong line indicator */
        if ((f2!=f1) || (f3!=f1) || (f!=f1))
            printf(" <");
        printf("\n");
    return 0;
  • \$\begingroup\$ Why is \$ \overline{x_3} \cdot \overline{x_2} + \overline{x_2} = \overline{x_2}\$? \$\endgroup\$ – jublikon Mar 4 '17 at 11:37
  • \$\begingroup\$ Because \$ \overline{x_3} \cdot \overline{x_2} + \overline{x_2} = \overline{x_2} (\overline{x_3}+1) \$, and \$ \overline{x_3} + 1 \$ is always true. \$\endgroup\$ – Marko Gulin Mar 4 '17 at 11:40
  • \$\begingroup\$ One last question: \$ x_2(x_4+x_0)+\overline{x_2} \$ Why is \$ x_2 \$ removed ? I thought that \$ x_2 + \overline {x_2} = 1\$ and both \$ x_2\$ negated and not negated should disappear \$\endgroup\$ – jublikon Mar 4 '17 at 11:44
  • \$\begingroup\$ I've expanded my answer to include a more detailed explanation. I hope this helps! \$\endgroup\$ – Marko Gulin Mar 4 '17 at 11:59
