No - the general feedback theorem is not necessarily to be applied. The shown circuit has two feedback loops - one with 100% negative feedback (unity gain) and one frequency-dependent network for realizing the filter function. Due to the internal phase shifts, this second loop provides positive feedback for a certain frequency range (in the vicinity of the pole frequency).
As a consequence, it is this network which determines primarily the phase margin and you can treat the active device as an ideal unity-gain amplifier.
Therefore: Set Vin=0, open the loop at the upper node of R1 and inject the test signal Vt (AC 1V, for example) at this point. Then, the loop gain is LG=Vout/Vt.
(In your text you mention the phase margin and the "open-loop transfer function". Please note that for finding the phase margin we need the LOOP GAIN which is the product open-loop gain (of the opamp) times feedback function).
EDIT (remark): To be more detailed, one must realize that the shown circuit has three loops (three methods to open feedback networks) - with different loop gains and, hence, each with (at least theoreticallly) different stability margins. That means: The circuit itself does not have a certain stabiliy margin - instead, each loop is equipped with a margin.
loop 1: Open only the RC-feedback path. Result: Gain margin GM=6 dB, no phase margin to be defined because the loop gain is always < 0dB.
loop 2: Open both feedback loops (RC path and short to the inv. input). Result: Gain margin again app. 6dB, phase margin PM=63 deg.
loop 3: Open only the short to the inv. input. As a result, both PM and GM are app. as for loop 2.
Comment: What is the meaning of a stability margin? Answer: Both margins give us an information which additional gain resp. phase shift might be introduced into the respective loop (that means: is allowed) until the circuit becomes unstable. Having this in mind, it makes no sense to open loop 3 (and to find margins) because a short is a short and cannot have any remarkable deviations. However, such unwanted influences (parts tolerances) may happen for the RC-network and for the opamp. For this reason, the first two simulations (loop 1 and loop 2) give results, which may be interesting for the designer. (The mentioned GM and PM values are simulation results obtained using the LT1001 opamp)
