I am trying to source this part http://www.theelectricbrewery.com/10-terminal-50A-ground-bar, but I can't find it at digikey. Is there another name?
  • \$\begingroup\$ While product recs are off-topic here -- you'll have better luck at an electrician's supply house with the type of thing you're looking for. Good luck! \$\endgroup\$ Mar 5 '17 at 15:13
Ground-bar is correct. But online purchase source may be better choice.
https://www.amazon.com/s?k=10+terminal+ground+bar+kit
  • Siemens ECGB10 Ground Bar Kit with 10 Terminal Positions
  • Square D by Schneider Electric PK23GTACP 23 Terminal Load Center Ground Bar Kit
  • PK3GTA1CP 3" Terminal Ground Bar Kit
or
POWER DISTRIBUTION BLOCK http://www.digikey.com/product-detail/en/adafruit-industries-llc/737/1528-1520-ND/5774323 enter image description here
