I have a 12V 66A Redox LiPo accumulator and a L298n motor driver (doc here: https://abc-rc.pl/templates/images/files/995/1426620157-l298-h-bridge.pdf). I couldn't find in the doc what is the driver's maximum supply current. Can I safely connect my LiPo to the driver, or is the current too high?
EDIT: solved: The datasheet says the max supply is 50mA, but the driver will take as much as it needs. Thanks @Andy_aka
  • \$\begingroup\$ Quiescent supply currents are specified on page three of the data sheet. \$\endgroup\$ – Andy aka Mar 5 '17 at 10:48
  • \$\begingroup\$ Ok, I see, thanks. So how can I reduce the current? I've 66A whereas the driver needs 50mA... \$\endgroup\$ – user141170 Mar 5 '17 at 11:06
  • \$\begingroup\$ The driver will take what it needs. It's ohms law. How much torque does a motor produce when unloaded? \$\endgroup\$ – Andy aka Mar 5 '17 at 11:08
  • \$\begingroup\$ Big thanks! Just to clarify if I understand correctly: to sum up, it is safe to connect this LiPo to the driver? \$\endgroup\$ – user141170 Mar 5 '17 at 11:09
  • \$\begingroup\$ Theoretically yes but that battery can produce a fire if not handled correctly. Use a fuse in series, maybe 3 amps. \$\endgroup\$ – Andy aka Mar 5 '17 at 11:10
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
