I'm trying to export a waveform from ltspice into an excel document to be later graphed using Matlab. I am simulating a simple series bandpass filter and when I export the voltage across a capacitor. It is not simply putting the voltage values into the second column. I am only given the option to use polar or Cartesian coordinates. Then when I am parsing the data in Matlab, it is not populating the variables because the second column is being occupies by coordinates. Can I change this export format somehow??
Maybe this is not what OP's after (and I misunderstood?), but it looks like he needs to add .option meascplxfmt=cartesian to the LTspice schematic prior to simulation. See the help for LTspice > Dot Commands > .options and look at MEASCPLXFMT for details. It allows three keywords: bode, cartesian, polar.
  • \$\begingroup\$ This helps me when viewing LTSpice Measurement in the SPICE Error Log, I'm expecting non-decibel measurement. \$\endgroup\$
    – Unknown123
    Commented Feb 28, 2019 at 12:28
You don't need to, thats the beauty of scripting languages.
First generate a text file with Cartesian coords. Use the importer to generate a script, like this: enter image description here then add a loop to post process the text.
>> Vn002{1}
ans =
8.53289842950458e-002,-5.03255593977887e-006
This is what the first value of my array looks like, but its a cell with text, so to get it to numbers you use sscanf. (%f means you want to convert an string with floating point format to a number.)
temp = sscanf(Vn002{1},'%f,%f')
dB = temp(1);
phase = temp(2);
This is for one line, I hope your able to put this inside a loop.
  • \$\begingroup\$ How does this get me to just the voltage value? I have this in my Matlab script. % read in data from excel get frequency values freq = xlsread('data.xlsx','A2:A5002'); % 50 ohms 5000 Hz series [num1,Vn001] = xlsread('data.xlsx','B2:B5002'); y1 = zeros(5001,1); for n = 1:5001 y1(n) = sscanf(Vn001{n},'%f'); end I'm only getting the first coordinate but when I have '%f,%f' I keep getting errors and do not know how to resolve them besides doing what I have done above. \$\endgroup\$ Commented Mar 6, 2017 at 20:24
  • \$\begingroup\$ Can you convert from dB to voltage? \$ dB = 20 × log (V_{out} / V_{in}) \$ where Vin is your source \$\endgroup\$
    – Voltage Spike
    Commented Mar 6, 2017 at 20:25
  • \$\begingroup\$ I am only able to get the first coordinate into my vector, would this still apply? \$\endgroup\$ Commented Mar 6, 2017 at 20:28
  • \$\begingroup\$ Don't use excel, use the data importer in matlab under TABS: Home-> Data import \$\endgroup\$
    – Voltage Spike
    Commented Mar 6, 2017 at 20:32
  • \$\begingroup\$ I figured it out, thanks for your help though. \$\endgroup\$ Commented Mar 6, 2017 at 20:44
