I am having some troubles soldering a S-PFQP-G80 package since I get solder bridges between pins after putting it into the reflow oven and I was wondering it would make sense to decrease the pad width in the footprint. I was hoping to get a bit more space between pads and prevent bridging. Currently footprint dimensions are 0.3mmx1.45mm and the pin width is 0.17-0.27mm. This being said I guess that I would have to reassure that the pins and pads are perfectly aligned.
The leads should get aligned when the chip is soldered, by surface tension pulling them into place. You should be able to decrease the pad width slightly. If it's only a few that are bridged you could use desolder braid.
