I apologize if this is foolish question, but I wanted to know how to connect a solar panel(that has no wires) to a breadboard. I wanted to test it out, but I am confused how to do it. Thanks for any help.
    \$\begingroup\$ You need to solder wires to the panel. \$\endgroup\$ Mar 6, 2017 at 20:06
  • \$\begingroup\$ Have you tried soldering some wires? \$\endgroup\$
    – Envidia
    Mar 6, 2017 at 20:07
  • \$\begingroup\$ Thank you! I was wondering if I should solder them, and if it would be ok. \$\endgroup\$
    – John G.
    Mar 7, 2017 at 0:58
Solder a wire to each of the gold contacts. You may need to scratch off any coating over them first. Then you could connect it as normal.
  • \$\begingroup\$ That, or spring-loaded contacts and a fixture \$\endgroup\$ Mar 6, 2017 at 20:11
