Is there any quick and easy way to determine if a microwave oven is leaking radiation from the door edges? By quick and easy I mean without buying a dedicated meter.
And if there is an undetected leak, how far do microwaves generated by a domestic microwave travel in air?
    \$\begingroup\$ How can it be quicker and easier than buying a dedicated meter? What you mean is "Is there a cheap way". \$\endgroup\$
    – pipe
    Mar 8, 2017 at 17:11
    \$\begingroup\$ One cheap way would be to test WiFi signal strength near a working microwave (assuming you have one running at 2.45GHz). \$\endgroup\$ Mar 8, 2017 at 17:22
    \$\begingroup\$ how far do microwaves generated by a domestic microwave travel in air? Microwaves aren't magic, they are radio waves at about the same wavelength as WiFi. So the loss due to the atmosphere in dB will be roughly 20*log(distance in m) + 40. \$\endgroup\$
    – Andrew
    Mar 8, 2017 at 17:38
    \$\begingroup\$ Weird, right before visiting this site, I put a Bluetooth speaker in my microwave to check if it blocks Bluetooth... (it doesn't) \$\endgroup\$
    – sweber
    Mar 8, 2017 at 17:52
    \$\begingroup\$ This is going to sound wrong, but run hour hand along the edge of the door or seam with the oven turned on. If it's leaking.... you won't hold it there very long....... trust me. \$\endgroup\$
    – Trevor_G
    Mar 8, 2017 at 18:31
What wattage/cm^2? Microwatts? Attowatts? All microwave seals leak. They may act more like a -60dB attenuator, rather than a perfect reflector.
If you're only worried about microwave heating (burns,) then any straight fluorescent tube-lamp will light up when held against a watts-scale door leak. Or, hold the terminals of an NE-2 neon lamp with fingers, and pass the glass lamp over the door seals, watching for orange flash. This is the same as tesla-coil lighting of a fluorescent tube. (Heh, actually a microwave oven chamber is a driven high-Q resonator. So in that sense the oven IS a 2.5GHz tesla coil.)
If instead you're looking for a high-milliwatts leak which might overload a receiver front-end, or perhaps hurt some sensitive electronics, then Tony_Stewart's trick with the red LED works fine. Simpler: two red LEDs soldered back to back in parallel, so both will light from AC. Add a 2" floating wire to to one side, hold the other with fingers as a ground, then pass the wire near the seal and watch for LEDs to glow.
I once took apart an active oven-leakage detector having a separate probe. The probe itself was a tiny pcb with a 1" ring trace, with six 1N4148 diodes soldered in a radial array, positive terminal pointing inwards to a central contact. The ring was ground, the pos terminal led to a resistor load and a 741 op amp. Obviously it was acting as a small loop, a nearfield probe-antenna with a diode detector. But they'd added five more in parallel, so the device would read roughly the same e-field regardless of probe orientation.
  • \$\begingroup\$ This is great. The fluorescent, neon, and LED tests are well within my competence - for which read doable. And I will definitely try them. Would I burn out the neon or tube if I placed it inside the oven? Also can I use a nightlight neon for this sort of test? \$\endgroup\$
    – John
    Mar 15, 2017 at 15:20
Spread the leads of a 5mm LED with zener protection into a dipole and hold the lens with leads next to the seam. If there is any dim glow then you have leakage.
If you put inside oven and turn on it will explode the lens off with a big pop.
  • \$\begingroup\$ SHOULD this work or WILL this work? \$\endgroup\$
    – Oskar Skog
    Mar 8, 2017 at 18:34
    \$\begingroup\$ With a high bright LED it should work with dim at ~500uA and the lead length makes a good antenna. \$\endgroup\$ Mar 8, 2017 at 19:35
-1
Put a cc of mixed water/fat on the external seam. It must remain cold.
Or try this:
    \$\begingroup\$ My doubts: The wire acts like an antenna? U have a diode so that both half (+ & -)waves don't result in NULL deflection. U have a LPF by that capacitor. V1 powers D1. Why is there a large resistor in series? BTW your water/fat answer is cool. \$\endgroup\$ Mar 8, 2017 at 17:57
    \$\begingroup\$ Can a 1N4148 deal with that high frequencies? \$\endgroup\$
    – Oskar Skog
    \$\begingroup\$ That circuit isn't going to work without a careful selection of components, a proper PCB layout, and an adequate board substrate. Don't use whatever through hole components you stumble upon when searching in your arduino breadbording bin. \$\endgroup\$ Mar 8, 2017 at 19:16
  • \$\begingroup\$ We boost sensitivity by turning ON the 1n4148 with 1uA or .1uA of current. \$\endgroup\$ Mar 9, 2017 at 3:11
  • \$\begingroup\$ This is not quick and easy. I am an "enthusiast with attitude" not an electronics guru. To put this in perspective the question I posted came about because I followed instructions on how to carefully dismantle a microwave (to extract the magnets and motors mainly) and this set off a train of thought on the dangers of a leakage. \$\endgroup\$
    – John
    Mar 15, 2017 at 15:24
