Using PIC32MZ2048EFH144 MCU.
Datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/60001320D.pdf
12 Bit ADC
The board has 8 DMA Channels(Programmable/Dedicated). I am interfacing 10 microphones, therefore i need 10 channels to connect my analog microphones.
How do I connect two analog microphones to one port on my board. Multiplexing? How so...? Any references you guys have?
  • \$\begingroup\$ It depends on your specs for Bandpass range, Nyquist prefiltering attenuation, SNR, THD, Dynamic range needed, and output requirements. \$\endgroup\$ – Sunnyskyguy EE75 Mar 9 '17 at 0:09
  • \$\begingroup\$ @TonyStewart.EEsince'75 Okay, but how would I connect them physically to the board, regardless of specifications of my end results. How would I connect two microphones to one channel. \$\endgroup\$ – tnet Mar 9 '17 at 0:13
  • \$\begingroup\$ There are lots of analog channels, already, but you need to condition the signal with an amplifier. \$\endgroup\$ – Sunnyskyguy EE75 Mar 9 '17 at 0:29
  • \$\begingroup\$ That microcontroller has 48 ADC inputs, according to the datasheet. Are you working with the microcontroller itself, or with a development board using that microcontroller? \$\endgroup\$ – Peter Bennett Mar 9 '17 at 0:38
