-1
Where in the UK can I buy 8 gauge stranded copper wire for high current applications (so not rly thin wire) relatively cheaply.
I've had a look around and couldn't find anywhere -
HELP!!
closed as off-topic by Ignacio Vazquez-Abrams, helloworld922, laptop2d, uint128_t, Leon Heller Mar 9 '17 at 6:46
This question appears to be off-topic. The users who voted to close gave this specific reason:
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ this is not the shopping forum \$\endgroup\$ – Sunnyskyguy EE75 Mar 9 '17 at 0:54
  • \$\begingroup\$ Shopping questions are off topic here, rephrase your qeustion. \$\endgroup\$ – laptop2d Mar 9 '17 at 4:28
  • \$\begingroup\$ Convert (from whichever of SWG or AWG you're using - they are different!) to mm^2, round up to next standard size, and buy that. \$\endgroup\$ – Brian Drummond Mar 9 '17 at 11:49
I assume "8 guage" is AWG (North American size). That is 0.1285 inch or 3.2639 mm diameter, so you might look for 3.25 or 3.5 mm wire in the UK. I don't know what the standard metric wire sizes are...
  • \$\begingroup\$ Since he's in the UK he might want SWG rather than AWG. \$\endgroup\$ – Brian Drummond Mar 9 '17 at 11:51
  • \$\begingroup\$ Metric wire sizes are given in sqaure millimeters, not millimeters diameter. Confusingly people often don't bother to write the superscript 2. \$\endgroup\$ – Peter Green Jan 19 '18 at 15:47
4mm D is 16sqmm is approximately AWG 8 £2.39/m
http://www.ebay.co.uk/itm/Copper-Welding-Cable-16mm-25mm-35mm-50mm-70mm-Battery-Cable-Earth-Cable-PVC-/232046811588?var=&hash=item36071159c4%3Am%3Amwwmvm_rjXE3Uj6QEs7EAWQ
