I need help finding where I have made the error in this problem set by my control systems lecturer.
The Question: The output of a linear time invariant system for an input \$r(t)\$ equals \$c(t)\$. If the input signal is passed through a block with transfer function \$e^{-s}\$, and then applied to the system, what will the output, \$y(t)\$, be?
The answer should be \$y(t) = c(t) \cdot u(t-1)\$ but I get \$y(t) = u(t) \cdot c(t-1).\$
My working:
Transfer function one, \$H_1(s)\$, applies to the original system. Transfer function two, \$H_2(s)\$, applies to the system including the new block:
$$H_1(s) = \frac{C(s)}{R(s)}$$
$$H_2(s) = e^{-s} \cdot H_1(s) = \frac{e^{-s} \cdot C(s)}{R(s)} = \frac{Y(s)}{R(s)}$$
Therefore \$Y(s) = e^{-s} \cdot C(s)\$,
\$y(t)\$ is the inverse Laplace transform of \$Y(s)\$:
$$y(t) = u(t) \cdot c(t-1)$$
