I have searched for a while information on how to put the silk side on the pcb ( without using an marker )
I have made an pcb with the toner transfer technique: You print with a laser printer over an glossy paper and then use the iron to pass the ink to the pcb on the cooper side, and after attack the cooper with acid )
Now i'm trying to pass the part that shows how components go on the pcb and they dimensions called the silk side on the side of the pcb that doesn't have cooper.
Question 1: Will the iron screw the pcb or is it any problems or danger doing this?
Question 2: Will the toner ink go off fast ?
Question 3: Is there another easy way to do this ? (Again without a marker )
