I am trying to derive an equation describing the cutoff frequency of a high pass filter op amp, as seen below: High-Pass Op-Amp
I have tried deriving the cut off frequency from it's transfer function: transfer function
But I can't get the intended result as indicated at the bottom of working? Is anyone able to spot where I am going wrong in my working or method of attack please?
working
  • \$\begingroup\$ Simple way to analyze ( in your head) is this is DC gain =R2/R1 and HPF breakpoint is Zc(f)=R1 then solve for f but assumes OpAmp an operate below Gnd so split supply or change bias on Vin+ \$\endgroup\$ Apr 9, 2017 at 11:46
For this circuit we have
$$H_{(s)} = - \frac{s R_2 C_1}{1 + s R_1 C_1} $$
So we have one Pole at
$$-\frac{1}{R_1 C_1}$$
And one Zero at the origin.
All this means that for low frequency the circuit behaves like an ordinary op-amp based differentiator.
With the gain $$A_V = \omega R_2C_1$$
And the gain reachs \$1 V/V\$ when sinal frequancy is equal to \$Fo=\frac{1}{2 \pi R_2 C_1}\$
As signal frequency increases \$Xc\$ drops and when \$Xc = R_1\$ we have a Pole:
$$\omega = \frac{1}{R_1 C_1}$$
$$Fp=\frac{1}{2 \pi R_1 C_1}$$.
And the the magnitude of a transfer function (voltage gain vs frequency) is equal $$A = \frac{\omega R_2 C_1}{\sqrt{1 + \left ( \omega R_1 C_1 \right )^2}}$$
  • \$\begingroup\$ @ConfusedCheese Also notice the the cutoff frequency is the frequency when the voltage gain drops -3db below the maximum gain. And this is not equal to \$\frac{1}{\sqrt2}\$. But \$\frac{R2}{R1}*\frac{1}{\sqrt2}\$ \$\endgroup\$
    – G36
    Mar 12, 2017 at 13:37
That's right, the -3dB point is at R1.C 1/radians, or 1/2.pi.R1.C Hz.
Were you expecting R2 to figure in there?
From inspection, you can notice that the inverting input is at a virtual ground because of R2. This effectively isolates R1 from R2, so only R1 and C affect the frequency response.
  • \$\begingroup\$ Sorry, i'm confused as how to arrive at that cut off frequency from the transfer function? \$\endgroup\$ Mar 12, 2017 at 12:22
  • \$\begingroup\$ So the impedance of the capacitor is low enough above the cut off frequency to allow those voltages through? But below that they are dropped across the impedance of R1 & C? \$\endgroup\$ Mar 12, 2017 at 12:37
Adding to Neil's answer:
The opamp holds its "-" input at a virtual ground.
R1+C1 convert input voltage into a current.
Opamp uses R2 to convert this current back to voltage at the output.
R1, C1 control cutoff. R2 controls gain/attenuation.
Note: Cutoff depends on signal source impedance! Your calculation is only valid for a zero-ohm impedance voltage source. Keep this in mind when using this circuit in the real world...
