I'm trying to understand NPN transistors by reading the chapter on them in Razavi's "Fundamentals of Microelectronics", and it says that collector current (Ic) is a function of the base-emitter voltage (Vbe):
$$ I_c = I_s \cdot e^{\frac{V_{be}}{V_t}} $$
where Is and Vt are constants.
In the following section, the beta value is introduced and it states that the collector current is base current times beta:
$$ I_c = \beta \cdot I_b $$
I'm confused whether Ic is determined by Vbe or Ib (or both?) since both these values can be controlled independent of each other using a resistor.
Can you give an explanation of how terminal currents and/or voltages are determined?
Pic for reference:
