I use an STM32F401C discovery board with STM32F401VCT6 microcontroller and want to set up a timer in one pulse mode, generating an interrupt after elapsed period. The interrupt handler is to toggle one of the outputs state.
I have generated the project, using STM32CubeMX, added the code starting timer and a callback to be invoked when an interrupt fires.
The callback:
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
UNUSED(htim);
HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
The line starting the timer operation in one pulse mode:
HAL_TIM_OnePulse_Start_IT(&htim10, TIM_CHANNEL_ALL);
Unfortunately, the program does not work as desired - outputs' state is not toggled.
The whole code of my main.c file is attached below. Clock configuration: APB1 Timer clocks: 25 MHz APB2 Timer clocks: 50 MHz
Could you please tell me, if I have missed something in my program?
main.c:
#include "main.h"
#include "stm32f4xx_hal.h"
TIM_HandleTypeDef htim10;
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_TIM10_Init(void);
//This code is never reached
UNUSED(htim);
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_TIM10_Init();
while (1)
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 16;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 8;
RCC_OscInitStruct.PLL.PLLN = 50;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* SysTick_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
htim10.Instance = TIM10;
htim10.Init.Prescaler = 50000;
htim10.Init.CounterMode = TIM_COUNTERMODE_UP;
htim10.Init.Period = 1000;
htim10.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
if (HAL_TIM_Base_Init(&htim10) != HAL_OK)
Error_Handler();
if (HAL_TIM_OnePulse_Init(&htim10, TIM_OPMODE_SINGLE) != HAL_OK)
Error_Handler();
GPIO_InitTypeDef GPIO_InitStruct;
__HAL_RCC_GPIOD_CLK_ENABLE();
HAL_GPIO_WritePin(GPIOD, GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15, GPIO_PIN_RESET);
GPIO_InitStruct.Pin = GPIO_PIN_12|GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
while(1)
Edit: I attach the rest of the code, I find relevant.
stm32f4xx_hal_msp.c:
extern void Error_Handler(void);
void HAL_MspInit(void)
//This function is called
HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_0);
/* System interrupt init*/
/* MemoryManagement_IRQn interrupt configuration */
HAL_NVIC_SetPriority(MemoryManagement_IRQn, 0, 0);
/* BusFault_IRQn interrupt configuration */
HAL_NVIC_SetPriority(BusFault_IRQn, 0, 0);
/* UsageFault_IRQn interrupt configuration */
HAL_NVIC_SetPriority(UsageFault_IRQn, 0, 0);
/* SVCall_IRQn interrupt configuration */
HAL_NVIC_SetPriority(SVCall_IRQn, 0, 0);
/* DebugMonitor_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DebugMonitor_IRQn, 0, 0);
/* PendSV_IRQn interrupt configuration */
HAL_NVIC_SetPriority(PendSV_IRQn, 0, 0);
void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base)
if(htim_base->Instance==TIM10)
__HAL_RCC_TIM10_CLK_ENABLE();
HAL_NVIC_SetPriority(TIM1_UP_TIM10_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(TIM1_UP_TIM10_IRQn);
void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base)
//This function is not called
__HAL_RCC_TIM10_CLK_DISABLE();
HAL_NVIC_DisableIRQ(TIM1_UP_TIM10_IRQn);
stm32f4xx_it.c:
#include "stm32f4xx.h"
#include "stm32f4xx_it.h"
extern TIM_HandleTypeDef htim10;
void SVC_Handler(void)
void PendSV_Handler(void)
void SysTick_Handler(void)
HAL_IncTick();
HAL_SYSTICK_IRQHandler();
void TIM1_UP_TIM10_IRQHandler(void)
HAL_TIM_IRQHandler(&htim10);
