After installing a grid tie inverter (GTI,) the power factor dropped from 1 to .85 over the last week. My loads are a combination of inductive and resistive.
I have an option of setting my GTI to feed .8 lag or .8 lead.
Which one should I use?
The default setting is unity.
I understand why the drop but what can I do about it?
My utility mandates a PF of .9 at least
    \$\begingroup\$ I don't read a problem. \$\endgroup\$
    Commented Mar 16, 2017 at 8:13
  • \$\begingroup\$ @andy Now theres one \$\endgroup\$
    – BUCKS
    Commented Mar 16, 2017 at 10:00
  • \$\begingroup\$ It is good to ask. But keep in mind that in a situation like this you can always just try it and see what happens. \$\endgroup\$
    – user57037
    Commented May 23, 2018 at 4:07
Set it to 0.8 lead for improving the overall power factor
