In Does conductance in the transmission line model represent a physical quantity? it came up that a non-real characteristic impedance just means the line has some loss. With real transmission lines having a little (but perhaps negligible) loss, we could expect all real transmission lines to have a characteristic impedance with at least a small imaginary component.
But is that really true? Let's say \$Z = Y = 1+1j\$. The characteristic impedance of this line is real:
$$ \sqrt{ 1+1j \over 1+1j } = 1 $$
And the attenuation constant is 1 [corrected by edit]:
$$ \operatorname{Re}\sqrt{(1+1j)(1+1j)} = 1 $$
Which to my understanding, means this line is lossless. But how can this be when it has both a non-zero conductance and resistance?
  • \$\begingroup\$ How is your second equation equal to 1? \$\endgroup\$
    – Envidia
    Mar 16, 2017 at 18:57
  • \$\begingroup\$ Because \$\sqrt{x^2} = x\$, and \$\operatorname{Re}(1+1j) = 1\$. \$\endgroup\$
    – Phil Frost
    Mar 16, 2017 at 20:30
  • \$\begingroup\$ Oh yes I was not paying attention to the Re() operator! \$\endgroup\$
    – Envidia
    Mar 16, 2017 at 20:50
  • \$\begingroup\$ I don't think the question was answered. The answer is no. You describe a lossy distortionless line which has real characteristic impedance \$\endgroup\$ Dec 5, 2022 at 12:04
Phil, the real part of the propagation constant is the attenuation constant and this equals: -
\$Re\sqrt{(R+jwL)(G+jwC)}\$ and not the formula you have in your question.
The formula you have used is for characteristic impedance.
This wiki page should confirm this (right at the bottom): -
So, if you do the math at low frequencies (to make life easier) you see that the attenuation constant becomes \$\sqrt{RG}\$ and if R=G=1 then you have a constant of 1 and a lousy highly lossy line. A lossless line has a re(propagation constant) of zero.
    \$\begingroup\$ Both the series R and parallel G are resistive and therefore loss components. \$\endgroup\$
    – skvery
    Mar 16, 2017 at 16:59
    \$\begingroup\$ Both the questioner and I know that but, the question is all about the real part of the propagation coefficient. \$\endgroup\$
    Mar 16, 2017 at 17:19
  • \$\begingroup\$ Ah whoops, that was a typo. But isn't \$\sqrt{(1+1j)(1+1j)} = 1+1j\$ still? \$\endgroup\$
    – Phil Frost
    Mar 16, 2017 at 18:41
  • \$\begingroup\$ At DC the attenuation constant is \$\sqrt{RG}\$ and if R=G=1 then the constant is 1 and therefore this is a big loss. It isn't lossless - it may be that you are confusing distortionless for lossless? A lossless line will have a constant of zero. See this: google.com/… \$\endgroup\$
    Mar 16, 2017 at 21:02
