I am relatively new in the design of DC/DC converters and have some difficulties with the selection of the switching MOSFETs for my design. To be completely honest, I am trying to find out if the already selected MOSFET (DMN3010LSS from DIODES Inc. and as second source the SM4832NSK from sinopower) by another designer is OK or I need to substitute it.
The specifications are:
- Vin = 12V
- Vout = 1V
- Iout = 12A
- PWM controller: MIC2102
- switching frequency: 437kHz
- inductor value between 1.5uH and 3.3uH (the last two are design choices)
My biggest problem right now is how to calculate the maximum current that will flow through the transistor and the maximum power losses. Naturally, I studied the datasheet of the controller, but I have the feeling that somehow some information are missing.
Regarding the MOSFET power loss, so far I have understood that it consists of two parts, the conducting power and the switching power loss. The conducting power for the high side is given by:
$$P_{cond,\ HS} = I_{out}^2\ \times\ R_{{DS}_{on},\ max}\ \times\ \left (\frac {V_{out}}{V_{in}} \right )$$
and for the low-side by:
$$P_{cond,\ LS} = I_{out}^2\ \times\ R_{{DS}_{on},\ max}\ \times\ \left ( 1 \ -\ \frac {V_{out}}{V_{in}} \right )$$
Is that correct? The MIC2102 data sheet is pretty crappy in this point: I suppose Eq.9 is incomplete; the duty cycle is completely missing!
Then, the switching power losses for the low side are negligible and can be ignored, as far as almost everyone says.
For the switching power losses of the high side MOSFET I tried to follow the information in the MIC2102 data sheet, but I was completely confused. Obviously one has to use Eq.12, where the switching transition time is given by Eq.11 (they say they have assumed that the turn-on and turn-off times are equal, which I haven't found anywhere else, but anyway). If we are to follow Eq.11, what is the difference between Vin and VHSD? To my understanding they are totally the same! Any idea?
Assuming that we finally compute the total power losses, how do I select an appropriate MOSFET?
Another topic is then: When selecting the MOSFET, what about the IDS current? How to choose the max IDS current that the MOSFET can accept?
