I am a bit confused to the answer given for the following question.
The question reads as follows:
If the input to a binary differential PSK modulation system is 01100101000111 tabulate The differential coder output
I know that for the differential coder output: 0 is encoded by the same pulse used to encode the previous data bit and 1 is encoded by the negative(opposite) of the pulse used to encode the previous data bit.
I am confused because Online and what I calculated does not match the answer that my professor gave.
My answer: For 01100101000111 input --> the output 001000110000101
Professors answer: --> 1 -1 -1 -1 1 -1 -1 1 1 -1 1 -1 -1 -1 -1
I found that this is only true if I first invert the input then apply the method, (in other words For 01100101000111 input becomes 10011010111000 )
Im so confused now, because I do not think that is how he obtained his final answer.
  • \$\begingroup\$ FWIW, it doesn't look right to me either. Besides nobody uses DPSK becuase it is not bandwidth efficient. But conceptually it is the same as Differential Bi-phase or Manchester codes ( 4 types) one of which became called Bi-phase Mark (toggle on 1) en.wikipedia.org/wiki/Manchester_code This then migrated to QPSK etc for analog and RLL encoding for digital and magnetic encoding. \$\endgroup\$
    – D.A.S.
    Commented Mar 17, 2017 at 1:57
You seem to have a binary system. This is how I would solve it. First, assume a "dummy" inital input and output of 0; then, if the current input is different from the previous input, output a 1; otherwise output a 0. It may be easier to place the data vertically:
input output
1     1
1     0
0     1
0     0
1     1
0     1
1     1
0     1
0     0
0     0
1     1
1     0
1     0
The sequence in your professor's answer looks wrong given the context. However, the reason they may be using 1 and -1 is that, in BPSK, a bit '1' is mapped to a positive amplitude V, and a bit '0' to a negative amplitude -V. The professor seems to have incorporated this step into their solution.
