The PCIe spec says that only one of MSI or MSI-X can be enabled. Else system behavior is undefined. What is the reason behind this? What is the problem if both are enabled for a PCIe function? Thanks.
MSI-X is a superset of MSI, if I'm not mistaken. Thus, enabling MSI-X means you've got MSI. No sense in trying to do both.
  • \$\begingroup\$ I understand there is no need to do MSI when the superset MSIX is available. What I am curious is, is there any problem if both get enabled? \$\endgroup\$ – user7656686 Mar 17 '17 at 15:54
    \$\begingroup\$ MSI-X is a very different capability from MSI, although it may utilise much of the same logic. pcisig.com/sites/default/files/specification_documents/… \$\endgroup\$ – Peter Smith Mar 17 '17 at 16:20
  • \$\begingroup\$ Hm, as far as I understood it, and kind of read the first page of that document, MSI and MSI-X have basically the same first 32 bit of the interrupt message, after which the MSI-X table comes in MSI-X; but, that document explicitly says "A function is permitted to implement both MSI and MSI-X", so my guess is that OP's simply encountering an arbitrary device restriction (without actual reason other than "we didn't implement it". \$\endgroup\$ – Marcus Müller Mar 17 '17 at 16:34
