I have tried checking with an oscilloscope on the analogue pins when the sensor is plugged in and I don't seem to get anything as I normally would.
The hardware i2c channel works just fine on the mega, its the soft ones I am trying to use that don't seem to work
#include <Wire.h>
#include <Ports.h>
#include <PortsSHT21.h>
#include <SHT2x.h>
//Define soft i2c channels for 3 sensors
  SHT21 hsensor2 (2); // pins A1 and D5 - Sensor 2
  SHT21 hsensor3 (3); // pins A2 and D6 - Sensor 3
  SHT21 hsensor4 (4); // pins A3 and D7 - Sensor 4
//define variables for temp data
  float h, t;
void setup()
    Wire.begin();
   Serial.begin(9600);
void loop()
   // Get data from first sensor hard I2C channel
    float hum1 = (SHT2x.GetHumidity());
    float temp1 = (SHT2x.GetTemperature());
    Serial.println("temp1");
    Serial.println(temp1);
  // Get data from second sensor soft I2C
  hsensor2.measure(SHT21::HUMI);
  hsensor2.measure(SHT21::TEMP);
  hsensor2.calculate(h, t);
    float hum2 = (h);
    float temp2 = (t);
    Serial.println("temp2");
    Serial.println(temp2);
   // Get data from third sensor soft I2C
  hsensor3.measure(SHT21::HUMI);
  hsensor3.measure(SHT21::TEMP);
  hsensor3.calculate(h, t);
    float hum3 = (h);
    float temp3 = (t);
    Serial.println("temp3");
    Serial.println(temp3);
 // Get data from fourth sensor soft I2C
  hsensor4.measure(SHT21::HUMI);
  hsensor4.measure(SHT21::TEMP);
  hsensor4.calculate(h, t);
    float hum4 = (h);
    float temp4 = (t);
    Serial.println("temp4");
    Serial.println(temp4);
    Serial.println("");
    Serial.println("");
    delay(500);
  • 5
    \$\begingroup\$ Same comment as for your answer from a few minutes ago: don't expect people to know what SHT21 is. Give more details if you want a proper answer. (Especially Olin is very sensitive to this :-), and rightly so) \$\endgroup\$
    – stevenvh
    Apr 4, 2012 at 16:32
  • \$\begingroup\$ I don't see any relevant code, like thouse for software I2C or for port setup: I2C ports need to be open-drain. \$\endgroup\$
    – Turbo J
    Apr 5, 2012 at 4:27
Just for completeness, I believe Jonny Flowers has found the solution himself: http://arduino.cc/forum/index.php?topic=99832.0
He's also put his code online: https://github.com/mrjonny2/PortsSHT21
His solution is to edit the Ports.h file's
uint8_t portNum;
inline uint8_t digiPin() const
    { return portNum ? portNum + 3 : 18; }
inline uint8_t digiPin2() const
    { return portNum ? portNum + 13 : 19; }
inline uint8_t anaPin() const
    { return portNum - 1; }
to
uint8_t portNum;
    { return portNum ? portNum + 53 : 19; }
    { return portNum + 53; }
  • \$\begingroup\$ Hi yes, I completely forgot about this, thanks for putting it in. Did you find it on my paste bin? \$\endgroup\$ Sep 2, 2012 at 15:20
  • \$\begingroup\$ Nah, I just googled and came across the arduino forum I linked in my answer. \$\endgroup\$ Sep 2, 2012 at 18:11
  • \$\begingroup\$ Ah, I remember posting it somewhere. \$\endgroup\$ Sep 3, 2012 at 15:28
