I want to know the comparison between the performance parameters of Tristate buffer and Schmitt Trigger. By performance parameters, I mean things like propagation delay,power consumption etc.
Thank you
Edit
I want to know, for example, if I use tri-state buffer as a repeater in a simple circuit, will it make propagation delay less than that if I use schmitt trigger as a repeater in that same circuit ? If so then why ?
