I am trying to reduce the current consumption of my Atmega328 -Arduino- by using the sleep modes. In my code, I want to wake-up every 10ms
, read the value from ADC, and go to the sleep mode again.
There are some useful instructions (here and here), but most of them are either based on Watch Dog Timre or external interrupt from pins.
Here is the simplified code of mine, but doesn't work (it doesn't go to the interrupt handler function):
In the setup, I take care of the Timer and its handler:
void setup() {
Serial.begin(19200);
Timer1.initialize(10000); //10ms sampling rate
Timer1.attachInterrupt(ReadMyADC,10000);
power_spi_disable(); // SPI
power_timer0_disable();// Timer 0
The rest of the code including loop()
is as follows:
void ReadMyADC(){
sleep_disable();
PRR = PRR & 0b00000000;
Serial.print("sth");
power_adc_enable(); // ebable ADC converter
//Read ADC
power_adc_disable();
void loop() {
// ----------------low power ---------------
PRR = PRR | 0b00100000;
sleep_enable();
set_sleep_mode(SLEEP_MODE_STANDBY);
EIMSK |= _BV(INT0); //enable INT0
ADCSRA = 0; //disable ADC
cli();
mcucr1 = MCUCR | _BV(BODS) | _BV(BODSE); //turn off the brown-out detector
mcucr2 = mcucr1 & ~_BV(BODSE);
MCUCR = mcucr1;
MCUCR = mcucr2;
sei(); //ensure interrupts enabled so we can wake up again
sleep_cpu(); //go to sleep
sleep_disable(); //wake up here
Serial.print("Wake\n");
Apparently, Timer1 is not able to exit the cpu from sleep mode. Do you have any idea how to manage that, or where the problem is?
