I'm trying to run this example because I have a DE2-115.
I get this debug output then I don't know what to do
nios2-flash-programmer --debug --epcs --base=0x0a001800 tPad_Selector.flash
Using cable "USB-Blaster [2-2]", device 1, instance 0x00
Resetting and pausing target processor:
OK
Processor data bus width is 32 bits
Looking for EPCS registers at address 0x0A001800 (with 32bit alignment)
  Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
  Not here: reserved fields are non-zero
Looking for EPCS registers at address 0x0A001900 (with 32bit alignment)
  Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
Looking for EPCS registers at address 0x0A001A00 (with 32bit alignment)
  Initial values: 108001C4 1004D0FA 002EE03A 003F9C06 002EE03A 003F9506
Looking for EPCS registers at address 0x0A001B00 (with 32bit alignment)
  Initial values: 00000000 00000000 00000000 00000000 00000000 00000000
  Not here: SPI_SLAVE_SEL has 0 valid bits (should be between 1 and 16)
Looking for EPCS registers at address 0x0A001C00 (with 32bit alignment)
  Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
  Valid registers found
EPCS signature is 0x16
EPCS identifier is 0x010216
No EPCS layout data - looking for section [EPCS-010216]
Unable to use EPCS device
Leaving target processor paused
What is needed?
If you read carefully the wiki page that you mentioned, you can find the following tip:
When you execute the 'nios2-flash-programmer' command, you may get an error like:
In such case, please refer the Altera forum page for the 'nios2-flash-programmer' or the section "A. Non-Standard Flash Memories" of "Nios II Flash Programmer User Guide" at pp.23.
Nios II Flash Programmer User Guide Appendix A: Non-Standard Flash Memories can be found here, pp. 27.
| improve this answer | |
