I am trying to interface the PSOC5 LP097 with PIR sensor to trigger the stepper motor for my Pet Feeder System. In addition, everytime the PIR sensor detects a movement, I try to send a mail using PySerial.
The problem I am currently facing is that the output of PIR sensor is always high when I try to read it via software. I tried to connect a LED to the PIR sensor output and it gets activated only when there is a movement in front of sensor. However, I do not understand why the software reads it as HIGH
always and keeps triggering the stepper motor
Below is my code:
#define MaxCountForTurns 300 //count for 2 rotations of the motor
int main(void)
CyGlobalIntEnable; /* Enable global interrupts. */
uint16 onCount = 0x00;
uint16 offCount = 0x00;
uint8 gateClose = 0x00;
uint8 motorON = 0x00;
uint8 pirValue = 0x00;
UART_Start();
for(;;)
if (gateClose == 0x00) {
pirValue |= pirInput_Read();
if ((pirValue & 0x01) && (motorON == 0)) {
motorON = 0x01;
UART_PutString("Pet movement detected : Motor will be turned ON\n");
CyDelay(10);
if(motorON) {
onCount++;
Control_Reg_Write(0x0c);
CyDelay(10);
Control_Reg_Write(0x06);
CyDelay(10);
Control_Reg_Write(0x03);
CyDelay(10);
Control_Reg_Write(0x09);
CyDelay(10);
if (gateClose) {
offCount++;
CyDelay(10);
CyDelay(10);
CyDelay(10);
CyDelay(10);
// turns in fwd direction
if(onCount > MaxCountForTurns) {
motorON = 0x00;
onCount = 0x00;
pirValue = 0x00;
CyDelay(50);
gateClose = 0x01;
// turns in reverse direction
if(offCount > MaxCountForTurns) {
gateClose &= 0x00;
The python code for sending the mail:
import time
import serial
import smtplib
TO = '[email protected]'
GMAIL_USER = '[email protected]'
GMAIL_PASS = 'psoc_pir_pet_feeder'
SUBJECT = 'Pet Feeder System Alert!!'
TEXT = 'PIR sensor detected pet movement, Motor will be turned ON'
ser = serial.Serial('COM2', 9600)
def send_email():
print("Sending Email")
smtpserver = smtplib.SMTP("smtp.gmail.com",587)
smtpserver.ehlo()
smtpserver.starttls()
smtpserver.ehlo
smtpserver.login(GMAIL_USER, GMAIL_PASS)
header = 'To:' + TO + '\n' + 'From: ' + GMAIL_USER
header = header + '\n' + 'Subject:' + SUBJECT + '\n'
print header
msg = header + '\n' + TEXT + ' \n\n'
smtpserver.sendmail(GMAIL_USER, TO, msg)
smtpserver.close()
while True:
message = ser.readline()
print(message)
if message[0] == 'P' :
send_email()
time.sleep(0.5)
I have tried doing the same project with arduino UNO and it worked perfectly. However here I see the following observations:
The motor turns in fwd direction once and reverse direction once.
Later on the motor keeps turning in fwd direction.
on PySerial :
message is displayed continuously. The mail is not being sent to the email id.
I realise that the PIR read which I try to do is not correct. However I dont seem to realise how to do it efficiently. Second question is related to the pyserial- I assume the serial port is busy with the response received from PSOC5 and hence does not proceed to sending an email to the specified address. Could anyone of you help?
Edit: I have fixed the motor turn issues, a simple bug in the implementation related to the offCount
. However I am still stuck on the pyserial part of the project. There is no email being sent to the email address. Suggestions are highly appreciated.
