There is a heatpump, which uses the following controller. How should one interface the heatpump, so the current water temperature (which is normally displayed only on a 4 seven segmen display, built in the controller) could be obtained and passed to a remote service.
I had two options in mind:
- Use a Raspberry pi zero and a camera to perform some ocr on the built in display.
- Use an ESP8266 or an Uno to interface either one of the 3 analog probes (which probably holds the temperature) or add an aditional ntc probe from the microcontroller.
How should one go about doing this? Thanks.
